GPV
- inne samochody terenowe
czarny bielsko
GPV
Post autor: czarny bielsko » pn gru 04, 2006 4:22 pm
GPV czyli General Purpose Vehicle: http://www.gpv.com/main.htm
produkuja dosc ciekawe pojazdy opancerzone z nepedem 4x4, 6x6, 8x8 i 10x10 :)2
ciekawe jak robia w terenie
Samurai - był
Terrano II - było
Pajero - było
czarny bielsko
Post autor: czarny bielsko » pn gru 04, 2006 10:53 pm
filmy sa niezle http://www.gpv.com/movies/GPV%20Vehicles%20Intro.html
http://www.gpv.com/movies/FMTV_Compare.html
ciekawe jak u nich wyglada spalanie na 100 i ile wyciagaja :)2
Samurai - był
Terrano II - było
Pajero - było
Misiek Bielsko
Post autor: Misiek Bielsko » wt gru 05, 2006 12:23 am
Jest tam gdzies spalanie i predkosc max. (ok. 100km/h).
Poczytaj dokladnie. Fajne maszyny :)2
charlie70
Post autor: charlie70 » wt gru 05, 2006 12:53 am
100?? To ja szybciej skociarnią pomykam :)21
Coby piwo smak piwa miało...
Misiek Bielsko
Post autor: Misiek Bielsko » wt gru 05, 2006 1:00 am
The GPV vehicle is capable of 62 mph (101 km/h) on land and can be easily geared up or down as required. In water, the GPV is capable of amphibious operations (excluding the 4x4 Sergeant and 8x8 Truck) of speeds up to 3.5 mph (5.6 km/h) without any additional modifications. Propellers can be added on to increase the vehicle speed in water.
czarny bielsko
Post autor: czarny bielsko » wt gru 05, 2006 9:17 am
znalazlem cos o spalaniu:
Fuel system consisting of three fuel tanks located internally totaling approx 150 gallons for reduced refueling intervals. This equates to about 1,050+ miles highway driving. Fuel is filled on the right side of the vehicle in the rear protected by thick, high-hard steel plate. A hidden latch that can also be pad-locked secures the fuel filler door. Fuel is transferred from the right rear tank forward to the right front tank and spills over to fill the left front tank. The front instrument cluster contains three separate fuel gauges and switches for selecting which tank the main engine draws fuel from. The fuel can be moved between the three tanks depending on what leveling is needed.
Samurai - był
Terrano II - było
Pajero - było
charlie70
Post autor: charlie70 » wt gru 05, 2006 10:20 am
Po wodzie to skociarnia 9km/h (wg instrukcji bo ja wymiękłem), spalanie ok 40l/100km, czyli mniej więcej 250 litrów diesla na rok :wink:
Wróć do „Inne samochodziki”
