crash vin dekodera
crash vin dekodera
Jako ze vin decoder jakis czas temu w jakis dziwny sposob sie popsul, a ja chwilowo niemam czasu zeby sie znow uczyc PHP wklejam tabelke [to troche za duzo powiedziane], na podstwie ktorej on dziala.
Dane pochodza ze strony Paddocka.
pewnie mozna by ja podac w jakis przystepniejszy sposob ale nie mam pomyslu w jaki.
Prefix
SAL - Land Rover
Model Range
123
***LB - Series 3
***LD - Defender
***LH - Range Rover Classic
***LJ - Discovery 1
***LN - Freelander
***LP - Range Rover P38A
***LT - Discovery 2"
Wheel Base
12345
*****A - 88' OR Trim Level 1 Free OR 100' Jap Spec Disco
*****B - 108' Euro Spec RR
*****C - 109'
*****G - 100'
*****H - 110'
*****K - 130'
*****N - 100' Cal Disco
*****R - 110' 24volt
*****S - 90' 24volt
*****V - 90' OR 108' US Disco
*****Y - 100' US Disco
Body
123456
******A - Commercial OR 3dr Freelander
******B - 2/3dr Station Wagon Defender OR 5dr Freelander OR 5dr Discovery
******E - 2dr 130' Crew Cab
******H - HCPU
******M - 4/5dr Station Wagon
******1 - 2 door Station Wagon
Engine
1234567
*******A - K 16 Petrol Freelander OR 1.8 P KV6
*******B - 2.5 Diesel OR 2.0 D TCIE
*******D - 2.5 Petrol
*******F - 2.5TDI
*******G - 2.25 Diesel OR 2.5 KV6
*******H - 2.25 Petrol
*******J - 2.25 Petrol
*******L - 3.5 EFI
*******M - 3.9 EFI or 4.0 EFI
*******N - 2.5 VM Diesel
*******V - 3.5 Petrol
*******W - 2.5 D BMW
*******Y - 2.0 MPI CAT
*******1 - 3.6 V8
*******2 - 3.9 V8
*******3 - 4.2 V8
*******4 - 4.6 V8
*******5 - 2.0 MPI Non Cat
*******6 - 2.5TDI Cat Def
*******7 - 2.5 TDI
*******8 - TD5 EGR/CAT
*******9 - TD5 EGR/Non CAT
*******E - TD4
Transmission
12345678
********1 - Man 4spd RHD
********2 - Man 4spd LHD
********3 - Auto 4spd RHD
********4 - Auto 4spd LHD
********7 - Man 5spd RHD
********8 - Man 5spd LHD
Model Year
123456789
*********A - 84MY
*********B - 85MY
*********C - 86MY
*********D - 87MY
*********E - 88MY
*********F - 89MY
*********G - 90MY
*********H - 91MY
*********J - 92MY
*********K - 93MY
*********L - 94MY
*********M - 95MY
*********T - 96MY
*********V - 97MY
*********W - 98
*********X - 99
*********Y - 00
*********1 - 01
*********2 - 02
*********3 - 03
Assembly
1234567890
**********A - Solihull
**********F - KD
Last 6 Didgits
12345678901
***********123456
Z Model Year jest tak myk, ze dany rocznik jest produkowany do wakacji.
Po wakacjach jest juz produkowany nastepny rocznik.
czy jakos tak... ;] chyba nic nie popieprzylem...
Prefix
SAL - Land Rover
Model Range
123
***LB - Series 3
***LD - Defender
***LJ - Discovery 1
***LN - Freelander
Wheel Base
12345
*****C - 109'
*****G - 100'
*****H - 110'
*****K - 130'
*****S - 90' 24volt
Body
123456
******H - HCPU
Engine
1234567
*******F - 2.5TDI
*******L - 3.5 EFI
*******1 - 3.6 V8
*******2 - 3.9 V8
*******3 - 4.2 V8
*******4 - 4.6 V8
*******7 - 2.5 TDI
*******E - TD4
Transmission
12345678
Model Year
123456789
*********A - 84MY
*********B - 85MY
*********C - 86MY
*********D - 87MY
*********E - 88MY
*********F - 89MY
*********G - 90MY
*********H - 91MY
*********J - 92MY
*********K - 93MY
*********L - 94MY
*********M - 95MY
*********T - 96MY
*********V - 97MY
*********W - 98
*********X - 99
*********Y - 00
*********1 - 01
*********2 - 02
*********3 - 03
Assembly
1234567890
**********F - KD
Last 6 Didgits
12345678901
***********123456
Ostatnio zmieniony czw sie 23, 2007 2:47 pm przez Roch, łącznie zmieniany 1 raz.
Landrąver Discovęry 200tdi
Cóś się mnie nie zgadza...
Witam,
Czy jeśli VIN od świeżo zakupionego w niemcowni autka się nie zgadza (wychodzą bzdury
) to jest powód do mocnego zastanowienia się, czy też są wyjątki od reguły?
Z góry dziękuję za konstruktywną odpowiedź...
From all the things I've lost,
I miss my mind the most...
...sam sobie jej udzielę.
Z przytoczoną listą cóś nie tak, pogrzebałem w sieci i znalazłem taką, według której mój VIN jest całkiem OK (SALLJGMF8TAnnnnnn)
http://www.angelfire.com/ca/TORONTO/VIN/landrover.html
4ty & 5ty znak - seria
LB Series III
LD 90 & 110
LH Range Rover Classic
LJ Discovery
LM Range Rover L322
LP Range Rover P38A
6ty znak - rozstaw osi
A 88" Land Rover, 100" Range Rover
B 108" Range Rover Classic
C 109" Land Rover
G 100" Discovery
H 110" Land Rover
M specjalny
V 90" Land Rover
7ty znak - typ nadwozia
A pickup, soft-top, truck, lub hardtop
B 2(3)-drzwiowy station wagon, 88" 90" & Range Rover, 2(3)-drzwiowy Discovery
H pickup o wysokiej ładowności
M 4(5)-drzwiowy station wagon
R Moneverdi Range Rover
8ty znak - silnik
B 2.5L turbo diesel
C 2.5L diesel
D 2.5L benzyna
E 2.4L VM turbo diesel ...a któś twierdził że LR z VM nie było...
F 2.5L TDI turbo diesel
G 2.25L diesel
H 2.25L benzyna
J 4.6L EFI benzyna
L 3.5L EFI benzyna V8
M 3.9L EFI benzyna V8
4.0L EFI benzyna V8
N 2.5L VM diesel
V V8 3.5L typowy gaźnik
W 2.5L BMW turbo diesel
3 4.2L EFI benzyna V8
EFI = elektroniczny wtrysk paliwa
9ty znak - skrzynia biegów
1 4-ro biegowa ręczna; kierownica po prawej
2 4-ro biegowa ręczna; kierownica po lewej
3 automatic; kierownica po prawej
4 automatic; kierownica po lewej
5 4-ro biegowa ręczna z nadbiegiem(??); kierownica po prawej
6 4-ro biegowa ręczna z nadbiegiem(??); kierownica po lewej
7 5-speed manual; kierownica po prawej
8 5-speed manual; kierownica po lewej
10ty znak - rocznik produkcji*
A wszystkie modele oprócz:
B Seria III CSW; Range Rover Phase II; 90/110 face lift do 1987
C 1986 Range Rover
D 1987 Range Rover
E 1988
F 1989
G 1990
H 1991
J 1992
K 1993
L 1994
M 1995
od T (1996) i dalej używane są standardowe oznaczenia roczników**
11ty znak - zakład montujący
A Solihull, Anglia
F Kompletnie Zniszczony (Completely Knocked Down)
* Rocznik produkcji liczy się od 1-go września roku poprzedniego do 31-go Sierpnia roku nominalnego. ...no murwa cwane...
** Rocznik produkcji
A 1980 2010 L 1990 2020 Y 2000 2030
B 1981 2011 M 1991 2021 1 2001 2031
C 1982 2012 N 1992 2022 2 2002 2032
D 1983 2013 P 1993 2023 3 2003 2033
E 1984 2014 R 1994 2024 4 2004 2034
F 1985 2015 S 1995 2025 5 2005 2035
G 1986 2016 T 1996 2026 6 2006 2036
H 1987 2017 V 1997 2027 7 2007 2037
J 1988 2018 W 1998 2028 8 2008 2038
K 1989 2019 X 1999 2029 9 2009 2039
I numeracja (literacja?
) powtarza się co 30 lat.
będę bezczelny, i jako kot pierwszy raz powiem:
no.
LB Series III
LD 90 & 110
LJ Discovery
LM Range Rover L322
LP Range Rover P38A
C 109" Land Rover
G 100" Discovery
H 110" Land Rover
M specjalny
V 90" Land Rover
8ty znak - silnik
B 2.5L turbo diesel
C 2.5L diesel
D 2.5L benzyna
G 2.25L diesel
H 2.25L benzyna
J 4.6L EFI benzyna
4.0L EFI benzyna V8
N 2.5L VM diesel
C 1986 Range Rover
D 1987 Range Rover
E 1988
F 1989
G 1990
H 1991
J 1992
K 1993
L 1994
M 1995
A Solihull, Anglia
no.
- czesław&jarząbek
- RAF z Ochoty
- RAF z Ochoty
- czesław&jarząbek
nie jest powiedziane.RAF z Ochoty pisze:no to jedank zostałem faknięty na roczniku przy pośrednictwie z Krakowa...
to lubie...
dane podane powyżej to nie całość zagadnienia to raz.
w niemczech funkconuje tzw pierwsza rejestracja. niezaleznie od vinu masz wpisany rocznik z pierwszej rejestracji.
w fabryce funkcjonuje system "model year..." czyli do wakacji biją win roku bierzącego, a po wakacjach już następnego co skutkuje gigantycznym burdelem w identyfikacji rocznika bo do tego dochodzą jeszcze terminy produkcyjne, czas transportu do odbiorcy, auta stojące na stock'u...masakra
vin to jedno
z vinu odczytuje się kompletację wozu i rocznik modelowy, a dopiero z cyfrowej końcówki numeru przy pomocy tabel można ustalić datę produkcji w przybliżeniu.
jeszcze poza kunkuresm moge dodać, że we francji jest jeszcze bardziej porąbane bo rejestruje się auta w "roku podatkowym" czyli w czerwcu. do czerwca rok w tył, od czerwca rok aktualny...przynajmniej jeszcze w latach 90tych tak było...
- RAF z Ochoty
- czesław&jarząbek
trza było papiery pokazać...
ale są gorsze przypadki.
np gdy aso sprzedaje ci używkę rocznik 2001 i za taką płacisz, a odbierasz dowód rejestracyjny w którym pisze 1999...
pewnie masz auto wprodukowane przed wakacjami, które przestało do nowego roku i wtedy zostało zarejestrowane.
standard.
z tego się biorą legendy o cysetkach 99...
standard.
I działajacy dekoder jako uzupełnienie:jacekwr pisze:...
LB Series III
LD 90 & 110
LJ Discovery
LM Range Rover L322
LP Range Rover P38A
C 109" Land Rover
G 100" Discovery
H 110" Land Rover
M specjalny
V 90" Land Rover
8ty znak - silnik
B 2.5L turbo diesel
C 2.5L diesel
D 2.5L benzyna
G 2.25L diesel
H 2.25L benzyna
J 4.6L EFI benzyna
4.0L EFI benzyna V8
N 2.5L VM diesel
C 1986 Range Rover
D 1987 Range Rover
E 1988
F 1989
G 1990
H 1991
J 1992
K 1993
L 1994
M 1995
A Solihull, Anglia
F Kompletnie Zniszczony (Completely Knocked Down)![]()
http://www.clifton.nl/index.html?calvin.html
Prośba, Misiul - o wklejenie zamiast tego niedziałajacego już Rochowego w temacie - "Pierwszy Polski .. itd" - dzięki
- czesław&jarząbek
no dokładnie czyta nasa, zaskoczyło mnie to jak coś tam sprawdzałem.. i pomyślałem, że cos z nim nie tak
, ale looz.
-może sie ktos podejmie zrobienia bazy na podstawie danych z "ksiazki", tymczasem proponuję wstawić tamten w miejsce "po Rochu" - bo jak sie szuka dxekodera nie przez swój komp "na placu" lub e 'terenie' to via forum jest łatwo dostępny.
w sumie nadchodza zimowe miesiace posuchy dla geodetow to moze i by dało rade wygospodarowac pare wieczorow na prace dla JEDYNIE SŁUSZNEJ SPRAWY. spocznij.czesław&jarząbek pisze:na bazie rochowego dekodera i danych pozyskanych w fabryce przez gazfana możnaby zrobić megazaejbisty dekoder obejmujący wszystko od początku produkcji aż do końca 2006 łącznie z nietypami i produkcją poza fabryką główną
Oka - to tak:czesław&jarząbek pisze: na bazie rochowego dekodera i danych pozyskanych w fabryce przez gazfana możnaby zrobić megazaejbisty dekoder obejmujący wszystko od początku produkcji aż do końca 2006 łącznie z nietypami i produkcją poza fabryką główną
W ramach odpoczynku niedzielnego zrobiłem VINa wg tabelki z tego wątku:
http://www.landklinika.pl/index.php?dz=vin
Zerknijcie, proszę wolną chwilą czy dobrze robi. Jeżeli dobrze robi to poproszę o dodatkowe dane - mogę wolnymi chwilami dłubać ten Megazajebisty.
No i jeszcze pytanie: czy podawanie swojego pełnego VINa wszem i wobec niesie jakieś zagrożenia ? Chciałbym, żeby na stronce ludzie podawali VINy swoich aut przy zapisach - wtedy mógłbym rozpoznawać autko. No i jednocześnie byłaby 'baza' naszych VINów - może by się przydała przy (tfu, ftu) kradzieżach czy przy śledzeniu historii naszych zabytków (bo przecież czasem serie przechodzą od Forumowicza do Forumowicza. Dobrze myślę, czy źle myślę ?
[edit]
A, jeszcze jedno. Jeżli chcecie/przyda się to mogę na szybko zrobić machinę szpiegowską - tak, żeby wszystkie sprawdzane na tym dekoderze VINy lądowały w bazie - ew. razem z IP sprawdzającego.
Disco 300TDi MY98
- czesław&jarząbek
słabo...
Twój numer VIN: saljy1242va732966
Znak Znaczenie Opis
1,2,3 SAL SAL
4,5 Seria
6 Rozstaw osi
7 Typ nadwozia
8 Silnik * 4.6L EFI benzyna V8
9 Skrzynia 4-ro biegowa ręczna; kierownica po lewej
10 Rocznik** 1997
11 Zakład montujący Solihull, Anglia
* EFI - elektroniczny wtrysk paliwa
** Rocznik produkcji liczy się od 1-go września roku poprzedniego do 31-go sierpnia roku nominalnego.
Znak Znaczenie Opis
1,2,3 SAL SAL
4,5 Seria
6 Rozstaw osi
7 Typ nadwozia
10 Rocznik** 1997
czesław&jarząbek pisze:słabo...
Dyć nie mówiłem, że to już jest ten Megazajebisty.
Ten jest zrobiny z tego co podał Roch i co ktoś potem wkleił. Badań na szeroką skalę nie prowadziłem jeszcze. Jak Cie znam to klepnąłeś swojego MY07 :p - więc proszę mi podać co powinno być w seri, rozstawie i nadwoziu.
A co do roku to faktycznie dałem ciała i nie zrobiłem zapętlenia. Poprawię się.
[edit]
uuu, sprawdziłem tym: http://www.clifton.nl/index.html?calvin.html
i faktycznie troche cienko 'mój' wychodzi. Dobra - wracam pod kamyczek - spróbuję usprawnić.
Ostatnio zmieniony ndz gru 02, 2007 11:28 pm przez ArturM, łącznie zmieniany 1 raz.
Disco 300TDi MY98
- czesław&jarząbek
No ale z tego co widzę to tam maja podzielone:czesław&jarząbek pisze:nie MY07
jego to nawet w wypasionej książce od fiflaka nie ma
NAS
rocznik wszedł, reszta z kosmosu
jedyne co sie zgadza to efi
J Model: NAS Discovery, 200/300 Series
Y Model specification: 49 state emissions, 100in
A ja mam serię tylko z dwuliterkowych skrótów - bo info tylko z tego wątku. Spoko - poprawię się. W każdym razie mam zrobione to co wiedziałem. Podstawa do usprawniania jest.
Disco 300TDi MY98
